I have a 2002 Dodge Dakota RT I would like to install a set of ion alloy 15 by 8 on the front 15 x 10 on the rear the front consist of 15×8with a -27 offset 83.82 mm hub, the rear 15×10 -38 offset same hub backspace is 4".will this work, please need input!!???
AS long as you can turn the front wheels right to left with out rubbing you should be ok.
I am also assuming this is a 2wd. If this is a 4wd, this will not work. Wider tires can be used on the rear, but they have to be the same exact same diameter.
Both axles have to turn the same speed.
Good Luck, Daddyododge
