Well, there were a few more fasteners than that. Sinse I hadn't seen this question answered well a couple different times, I made this pic.
A - To access these 8 expanding plastic screws, you need to lift the hood and remove the corner lenses. Space is extremely limited. They are designed to unscrew, but I just used a special tool to pull them straight out. The tool is pictured below.
B - These are accessed from inside the wheel well, and I used a T25 Torx on them. It wasn't the perfect size, but it worked great.
C - These are more of the expanding plastic deals. Again, I just pulled them straight out.
D - These are push-in style things (love the technical terms here?) that are designed to be pulled straight out. They attach a rubber extension from the bottom of the bumper cover to another cover under the engine. When you are removing these, it's a good time to unplug the fog lights.
