1 - 9 of 9 Posts
i installed new coil, cap n rotor new plugs and oil...so things seemed fine. i took it for a drive nice good throttle response...BUT....it shifted from first straight into third, i thought maybe the pcm needed to be recet, buti stupididly I left one of the tb cables loose, but before i noticed it i reset the pcm(purged it) thinking i was having issues with it, and now when i start the truck its revving at 2grand and for about 2 minutes i let it run and it didn't come down... any suggestions or tips, i know i've read about this before but help would be appreciated.
Did you re-connect the TB cable back in the correct location? Check to see if the throttle plates are open at idle, if so see if they are in a bind.
Discussion Starter #4
yah all fixed guys... turns out if you ever have the same issue instead of dc the neg disc the positive baddabing, now she runs pretty good, but i think my fuel filter is clogged up :( having some surging issues on cold runs
What up all
What up every body im new here i just got a.. 02 dakota slt awd it run's like a skallded dog hit has a wineing noise is it supercharged??and how could i check to see if it has a chip n it ???? This is the first dodge ive owned and i like so far ....... Yall prob be seen me around here so any help or trick's ya no tyvm ....p.s i know i did this wrong i didnt no were to post any thing yet
Texas, Pffffft
Talk about digging up ancient threads. I would start with a new thread. This one is pushing on 7 years old.
dont matter which cable you unhook, either way breaks the circuit. common practice however is unhook neg 1st//// reconnect neg last.
what up all if any body out here had or has a dodge dakota slt have yall had any prob's with the tranfer case i dont get on it 2 much but when i take off slowly it has a big bump or jerk or pop.... what ever ya call it ya get the idea? and i was wondering what kind of chip's there r for it ????? ..... if ya be so kind to help a brotha out !!!!!!!.......(pce) :banana2:
1 - 9 of 9 Posts
