1 - 10 of 10 Posts
... well my HO cams arrived on Saturday. I have read a number of threads here about lash adjusters popping off. Some people attribute it to oil temp / viscosity on cold starts.
I have 3 questions:
Should I (and why or why not) switch to those faster beehive springs or use the stock springs?
Should I (and why or why not) switch to those solid lash adjusters or use the stock ones?
Is there anything else I should do or any other comments?
Hopefully next week, I can get back to it. work is keeping me busy.
Thanks,
Kevin
Discussion Starter · #3 · (Edited)
...daily driver, some towing once in a while, will never see a dragstrip. HO cams are just low hanging fruit for an upgrade with it all being apart right now. It was stock when I took it apart. I will probably have Dwight bore out my TB. Other than that, nothing yet. Will put a cold air intake on as it goes back together.Pretty much everyone agrees that the cams will wake it up a bit though.
Kevin
Replace the LA's with a set of new OEMs, that should be more than enough. I'm not sold on the solids yet.
Where did you get your cams from if you don't mind me asking?
Discussion Starter · #6 ·
1 x Mopar Performance 1999-2007 4.7L H/O Camshafts (Mopar 53x21412AD, 53x21411AD) = $285.00
Original Chrysler equipment. I got them from a guy in MO called 3rd strike performance. I think he is a one man operation but he was able to get them. It is worth checking for availability before ordering. They showed up on Saturday. Total of $293.95 after shipping to my doorstep.
Kevin
Thanks for the info! i will hopefully be able to buy a set by spring.
My shop is rapping me on my lift :(
Discussion Starter · #8 ·
Ryan, Can I ask why you are not sold on them?
Sure. For something that isn't raced, I don't see why someone would have to go to solid LA's. The hydraulic ones do the job, they just need replacing after a while. Most valvetrain parts are like that.
I'm not saying they don't work- they look like nice pieces but for your purposes the OEM LA's would more than able to handle what you're doing.
From my standpoint, I drive 20-30k a year and I have no desire to have a date every 3,6,9 months with my valve covers.
1 - 10 of 10 Posts
