Nope.I have a 2001 ram 1500 5speed v6 with a lot of miles on it. The waterpump just went out on it and I have access to a carberated 360 to drop in relatively cheaply. All I need different is a flywheel right?
You can still use your ECM for the spedomitor and all of your gauges except for the tachometer. And you need external regulator for alternator and hopefully you have a transmission 46,47or 48 re rh or 727 would be the easiest. O yeah fuel pump regulator or mechanical pump.I have a 2001 ram 1500 5speed v6 with a lot of miles on it. The waterpump just went out on it and I have access to a carberated 360 to drop in relatively cheaply. All I need different is a flywheel right?
