Bigguy18LSU77 said:
I tried to start my dak to go to school on monday and the lights came on and the radio came on etc. but it wouldn't turn over. Just gave a clicking sound, like it's trying to turn over but cant. The batter has to be good or the lights etc. wouldn't come on right? So it would be the starter? (my mom seems to think it's the alternator) lol....
Anyway, if anyone knows what really IS going on, let me know please and how to fix it too if possible.
Thanks,
Hugh
It's your battery. 1st...Make sure your connections are free of corrosion and are on tight. Then try to start it up again. If no good, then take your battery down to Autozone or an autoparts store that checks them for free.
But then again I got to stop myself. Here comes a lengthy story...heh'
The other day my truck didn't want to start as well, everything came out, lights, radio, etc. But it didn't want to turn over at all, not even a clicking sound. I even got a boost to see if it would work, no good. Because I wanted to get home (I was at work 30 miles away). I went down the street to an Autozone, bought a new battery, installed it, and bam, it turned on.
The next day I got my old battery (Interstate) tested, and they said it passed and it's fully charged! So I don't understand what happend. I'm going to go ahead, and install the Interstate battery again to see if it works, if it does, then I'm returning the new battery, if it doesn't then at least I have a new battery.
Another thing I was told was to check the starter, it could be stuck, or a wire came loose down there. I was going to get under the truck, and check it. But I figured the easiest solution to try first was to change the battery, and sure enough it worked.
So in conclusion, lol, I'd buy a new battery first to see if it's your problem. If it still doesn't turn on, then it's probably your starter.
Now once you get a new battery, and it's running, drive it around awhile, with the radio, lights, etc on......stop, somewhere, like your house, and turn it off, turn it on a few times to see if the alternator is working, you can tell by looking at the battery gauge. If it keeps going down, then it's the alternators fault for killing your battery.
Phew, sorry for the long post!
