1 - 20 of 256 Posts
· Premium Member
To date the 4.7L has 4 intake manifolds available.
  1. 1999-2001 INTAKE MANIFOLD - WORST DESIGN... REPLACE ASAP!
  2. 2002 INTAKE MANIFOLD - IMPROVEMENT OVER 1999-2001 INTAKE MANIFOLDS
  3. 2002 H/O INTAKE MANIFOLD - Once considered the best factory intake (No longer available)
  4. 2003 INTAKE MANIFOLD - Improvement over the 2002 INTAKE MANIFOLD and comparable to the 2002 H/O INTAKE MANIFOLD
  5. 2008 INTAKE MANIFOLD - HANDS DOWN THE BEST DESIGN! Current 2008 4.7L makes over 300HP!
Up till today the 2008 INTAKE MANIFOLD could not be used on the older 4.7L engines because its uses a PCM controlled throttle body with a 4 bolt pattern throttle body and you could not mount your cable throttle body to it... until now.
We now have CNC'ed bullet adapters available to allow you to mount your 1999-2007 cable throttle body to the 2008+ Intake manifold. This will allow for a PLUG & PLAY set up and come with the needed Throttle body Cable bracket and all hardware needed to install. These high quality CNC'ed machined adapters make use of rubber seals for a reusable sealing surface.
This intake is the best FACTORY intake ever made... the new 4.7L is making over 300HP with this INTAKE MANIFOLD!
CLICK HERE TO VIEW THE 2008 4.7L INTAKE MANIFOLD COMBO PACKAGE!
2008 INTAKE MANIFOLD​
INTAKE SPACER (A INSTALLED)
INTAKE SPACER (A+B INSTALLED)
INTAKE SPACER (A+B+ 2003 THROTTLE BODY INSTALLED)
If there are any questions please feel free to contact me.
SPEED SAFE, AIR RAM
· Rockford Mopar
Do you know how much more HP/TQ the 2008 intake makes over the 2002 H/O Intake manifold ?
· Let it SNOW!
there are other things different between the 08 4.7s and the rest, right? quoting that the new 08 4.7s do over 300hp is useless info at this point. we have no benchmark. from your personal observations, what is different between the ho IMs and the 08 IMs?
· Premium Member
Discussion Starter · #4 ·
Well although Im not suggesting adding this intake will instantly gain you 300HP I am suggesting its currently the only one that supports over 300HP.
Just by looking at it compaired to the other intakes, its clearly a better built intake... I dont need to run it to ditermin that, anyone with some experience can tell you its a better design... but how much better is the hard part to predict.
This intake has been rumored to be the best intake to have long before its release... This is from a chrysler Dyno Tech who literally tested them on the 4.7L engines... So I have no doubt its the best FACTORY intake hands down.
Time will only tell exactly what gains will be had... but rest assured, if your adding allot of mods and want the edge... this intake will be a great addition to your project.
SPEED SAFE, AIR RAM
SPEED SAFE, AIR RAM
· Premium Member
Discussion Starter · #7 ·
so, in short: this is the best intake available for our trucks, dollar-wise AS LONG AS we aren't doing any forced induction?
There is no doubt that this intake will be the best N/A FACTORY intake manifold available. And I would not doubt that it could handle 10-12lbs of boost.... So it could very well be good for low boosted engines.
· Rockford Mopar
it's $575 if you buy the intake manifold and adapter plate together.
$290 for that? There can't be more than 1.5hr of machining on that. Could be way less time if you were doing a bunch and made fixturing, but that's likely not the case. Figure $80 an hour shop time and you got $120 machining cost. Sure as shit isn't $170 in material there.
:huh:
Don't get me wrong, I love the idea but you won't see me paying $290 for that.
:huh:
Word.
I'm going to see what retail price is on the manifold, as well as my cost--just for the hell of it.
· Premium Member
Discussion Starter · #15 ·
In order to make this work and allow you to mount your pre 2008 throttle body to the 2008 intake we had to have two adapters made. It was not possible to do this with just one adapter. We also have them grooved to allow for a the stock rubber seal and a rubber o-ring between the two parts. Allot of R&D went into them... This is not "JUST AN ADAPTER" there was more to it then that.
As for the cost of running the 2008 intake on your 1999-2007 4.7L... People spend over 300 bucks on just an induction system that offers less of a gain with out increasing the total potential.
Now if you guys would like to get a GP together we may be able to do so something... But one at a time the price would have to be about where its at.
Also this is all with free shipping, something many people seem to forget. That's 35-45 bucks off the top right there alone that we have to cover to get it to your door.
So If we charged 530.00 + shipping it would look better on paper but in the end you would pay the same price.
If you look at everything we offer on our site its clear we do everything we can to bring you the best parts for less. If we can cut prices we do. So its not like we are jacking the price up to make a huge profit... but we do need to make something.
If this is too expensive for you, then perhaps this mod is not for you.
SPEED SAFE, AIR RAM
· Donating Chicken Helmets
It would also help if we knew how much of a gain that intake would be over ther other intakes.
I too would be interested in its performance. I understand what he's saying that the newest version is supporting 300 hp, but what is the hp limit of the H.O, or 03 design? Maybe a hp level where the money spent on this is a good idea. I'm guessing its arrival and your being out of the country makes it difficult to test, or where preliminary testing done a while ago?
· Up then Down then Up then
How much are the 08 Heads?
1 - 20 of 256 Posts
