1 - 1 of 1 Posts
· Vendor
The reality is that TPMS warning light flashing on your dash might be pretty confusing, cause you never know, which out of 4 tires came out of the order. Even though you might check your tires regularly, you can't eliminate the risk of sudden flat tire completely. So ensure that all 4 tires on your ride maintain sufficient pressure and avoid the early wear, blowouts and improve the fuel economy by installing wireless 4-Tire Dash Mount TPMS Kits by Torxe.
They are manufactured to provide you with the up-to-date information on a pressure of each tire of your car and alert you if one of them is losing air, these kits will enhance your driving safety and make your driving process more safe and enjoyable. Those are solar power devices, that won't drain your battery, so you won't get any unpleasant surprises in the morning. They are set up to turn on immediately once your vehicle is on the go and shut off when it is standing still. Make sure your tires are inflated properly with our easy to use and install Torxe TPMS Kits, see the options below to find one the most suitable for your driving needs:
* Torxe® TPMS-03 - 4-Tire Dash Mount TPMS Kit at CARiD
** Torxe® TPMS-04 - 4-Tire Dash Mount TPMS Kit at CARiD
Transmission frenquency: 433.92MHz;
4 pieces internal sensors;
Sensor pressure range: 0-116psi(0~8bar);
Sensor working temperature: -40°C to +85°C;
Transmission power: less 10dBm;
Proper tire inflation is crucial for optimal driving and handling. Stay on a safe side with us, install our solar powered Torxe TPMS Kit today and be confident and aware of any changes in your tires pressure.
Follow the link below to read more Torxe:
https://www.carid.com/torxe/
1 - 1 of 1 Posts
