So I've got something weird going on with my 4.7
A couple of weeks ago (on a Wednesday) I installed bwdakrt's 4.7L throttle body. That weekend I changed the oil (Mobile1 5w-30 with a pureolator pureone filter) and also changed the pcv valve (I had bought one during the summer and just never got around to installing it). Everything was fine.
That Tuesday the temp had dropped into the low teens, and has been there ever since for the most part. I noticed a burning oil smell on the way to work and checked and found the back of the intake and down onto the top of the back of the motor had a thin film of oil on it. It's been burning off here and there ever since, but ive just kind of ignored it, figuring eventually it'd all burn off and go away.
Today it got really bad again, so I checked and it seems like again there's a somewhat fresh oil film covering the back of the intake. I thought maybe the gasket around the new TB wasn't sealing well and it was leaking out of there. I pulled the TB off thinking id just put some RTV around it and found the intake has some of that foamy moisuture/oil mixture you get in the filler tube sitting in the front and also coating the neck. The back of the TB also had some moisture on it. But doesn't really show any signs of oil leaking around it anywhere.
What the heck is going on here? I don't know if it's related to anything I did or just the weather. I know the 4.7 gets that oil/moisture mixture a lot in filler tube when the weather's cold but I've never had anything leak on me before.....
Thanks
Thanks
