I have a 2001 Durango with the 4.7L engine. It overheated this last winter and it is leaking oil into the cooling system. I took it to a local shop and they tested the Cooling System for hydrocarbons, which found 1083ppm hydrocarbons. You can also smell radiator fluid in the exhaust. The shop said the engine needs to be replaced.
Is the shops assessment that it needs a new motor sound right? or should I get a second opinion? It still runs and drives for about 5 miles before overheating, so I am not sure it is a total loss. Maybe just new heads?
Also, I was looking to see if there is someone/shop in Sacramento or possibly in SF Bay Area that people on here would recommend. I don't have a lot of money to put into it so cost is a factor.
This is probably a long shot but I'd actually like to assist so I can learn how wrench on it myself, and maybe it would save a little $.
Sorry for the long message. I appreciate any advice that you all can give.
Thanks, Matt
Thanks, Matt
