1 - 6 of 6 Posts
Hey guys... got an 03 Dakota Stampede... just wondering how often that fluid in the limited slip should be changed... i can't believe that 25K- 30K kms interval that Dodge says could actually be right...
When you change it, put in Royal Purple and you can double the interval AND you won't need a friction modifier either.
Discussion Starter #4
So is what Dodge says the interval is correct or am I just flushing money down the drain?
that's what it says in the manual. unless you sink your axles under water. did you want it further or closer???? :D
Discussion Starter #6
yes but Dodge also thinks that their ball joints are 'lubed for life'... guess i'll have to save up and change it soon then.
1 - 6 of 6 Posts
