Well the truck has almost 206k on it and the lower control arm bushings are bad and i was told that you can only replace the whole control arm... and there about $186 from the dealer ... Is there any other ones out there that don't lower the truck that are cheaper?? I really don't have the money but there about to go out and the sqeaking is hellaish (sp?) thanks for any help
is it 2wd or 4? if its 2 energy suspension makes urethane control arm bushings. if its 4wd u should try to see if MOOG makes replacements.
Its 2wd ..I'll have to check them out thanks
