New Venture transmission were made for Chevy and Dodge trucks.just a little side note.The nv3500 is not a dodge transmission,but a new venture transmission made for dodge.I would think there are parts made to beef up a 3500 and even change some of the ratio's of the gears.Instead of asking dodge,try asking new venture for tips.
I would, but I couldn't use my Hurst shifter then!... buy a Tremec...
Wow, I did not know that!It comes with a new Hurst shifter, but thats a very important arguement! I agree it MUST have a Hurst shifter haha
Thought that was funny, made me laugh.Guess what, straight from Tremc:
http://www.ttcautomotive.com/English/onlineorder/pdf/TKO_Installation_Tips_117_117.pdf
"Using an aftermarket shifter may void your warranty. If an aftermarket shifter is used, remove the shift stops. All TREMEC transmissions have internal stops and can not be over shifted."
You must be Popeye or something. I've never overshifted mine. I have gotten it stuck between gears when working on it, but never over shifted.
My guess is you over shifted it and the shift dog went beyond it's stop. On the fron of the tail housing, forward of your shifter, is a silver access cover with 4 allen head screws. Remove that cover. When you look down in there, you'll see the 3 shift rails. If it is stuck in 2nd, the rail on the passenger side will be forward of the other 2. Simply take a flat tip screw driver and pop it backwards so that it lines up with the other 2. What this does, is knock the transmission back into nuetral. From there, test shift it and make sure it is good. Then re-apply RTV to the cover and bolt it back down.
Richard
Tech Support
What color is the shift tower? If it is red, I can send you an adjustable shift stop that will prevent that from happening again.
These tranny's are built tough and no, I am not suggesting to baby it. Why it happens, I'm not sure but I have run itno this a few times in the past.
You didn't damage the gear box so don't worry about that, just let let me know what color the tower is so I can help you out.
Richard
Tech Support
Sr.did you ever finish up your nv3500 to 5.7 swap,just wondering how it worked out, i'ed like to do a manual swap in my ram I have the nv3500 parts,but also have a nv4500 that need built,thanksThe bolt pattern on the NV3500 will bolt right on a 5.7 hemi. I've done it in the shop...
