1 - 11 of 11 Posts
Hey there. Ive been looking to purchase some new springs for my '98 Durango (5.9l 4wd) as mine are completely clapped. I've looked at a few and found some inconsistency between the weight capacity. I've found ones for 2250lbs and 1800lbs part numbers 34-1405HD and 34-1405 respectively.
Does anyone know the OEM part number or, the OEM weight capacity for these?
Thanks
Who did you get them from if you don't mind me asking? I bought add-a-leaf for mine. I might just go with newer ones along with the add-a-leafs also. Thanks
Try ATS Springs in PA for replacement leaf springs and other replacement hardware. They sell both the 5 leaf standard springs (1800 lbs) and the 6 leaf heavy duty springs (2400 lbs). I bought my leaf springs from them about one year ago and they had by far the best prices and are well made. Service was good also.
I bought the standard springs because at the time I was a short on cash and also don’t tow much with my Durango. The springs went on easy and have worked out fine, but I would buy the HD springs if I could do over again. I don’t think the difference in ride quality would be noticeable, particularly with a loaded vehicle, as it is just one added spring.
Discussion Starter · #10 ·
Thanks man!
I will definitely check them out
1 - 11 of 11 Posts
