Kenne bell 1.5 supercharger with manifold. Also includes the following.
-brackets for mounting supercharger and relocating alternator and A/C.
-39lb fuel injectors
-2 bar map sensor
-70mm throttle body
-Sct tuner
-original kenne bell boost a pump and wiring.
-boost gauge
Walbro 255 fuel pump/fuel level sender assembly
-wide band o2 sensor
the only issue is the bracket to relocate the alternator needs welding as it cracked in two. The boost bypass valve was repaired in the past but works as it should. Also have other parts including HO manifold and super chips tuner. Reason for selling is my motor had an oiling issue destroying the engine. Between the motor and rust and other issues she’s too far gone.
-2 bar map sensor
-70mm throttle body
-Sct tuner
-boost gauge
