1 - 12 of 12 Posts
"][" {[]} {[]} ][_
Starting to part. Uninstalled stuff goes first.
Trans is gone.
Bell housing
Cross member adapter
Clutch and pressure plate for tko.
Inner and outer shift boot 97-2000.
Clutch fork
Shifter and ball
Pedals
Inspection cover
Manual column cover
Other odds and ends.
Not willing to separate at this time.
Asking 1300.00
Don't be "That Guy"
What's your cross member adapter look like? I might be able to use it with my T56....if you're willing to start parting...
"][" {[]} {[]} ][_
Discussion Starter #4
Not wanting to part yet.
Gold piece only. Mount is tko it might fit t56 idk.
Don't be "That Guy"
Looks the same as T-56. thanks!
is there rubber/poly anywhere, or does that make a hard/solid mount?
"][" {[]} {[]} ][_
Discussion Starter #8
It is metal on top and bottom rubber in the middle. It is the trans mount. Isolator etc.
Currently embracing Fords
Subbed just incase I miraculously come across some money or if you decide to part.
1 - 12 of 12 Posts
