1 - 16 of 16 Posts
Need input on those of you running this particular 2bbl TB. As of now I am running a 52mm F&B TB and would like to know would this be an upgrade in performance or just run the current TB I have now? I like the F&B line of TB's but I hear you will have to modify the M-1 if you go bigger then a 52mm. Do you have to modify the JM TB as well?
408, m-1, headers, 2.5 duals, eddy heads, 2600 stall, rr, n2o, shift kit, 4.56 gears, comp cam, 10.8 comp and other little stuff...
Blown and Squirted
Which m-1? If it is not a 4bbl I would swap it out at the same time. (modifying the manifold, or 2-4bbl adapter is not a bad thing, it would be worth the effor to go bigger)
I would say you are past the 52mm throttle body. There hasn't been much feedback on the single blade, or a third part comparison yet. How does the price compare to F&B's larger offerings?
I can't help but think tip-in control is going to be worse with the single blade throttle bodies, it is for all the mustang offerings. With a big cube high compression motor and not much converter, it might be a bit touchy in traffic.
Blown and Squirted
That 2bbl is choking you motor out just as much as that 52mm throttle body.
You can sell it for more than a 4bbl costs new, it should help pay for your throttle body upgrade.
The 2bbl M1 will be fine unless you want to spin some higher RPMs. I'm running a 52x55 F&B on mine and I had to open up my 2bbl M1 a little, but nothing a little work with a dremel tool didn't fix. Even with the 4bbl M1, you will still have to do the same thing to the 2bbl adapter on it. And as mentioned, I can't imagine the throttle response on the single blade JM TB is very fun.
registered abuser
I bought the one that was recently up for sale. It's a little touchy right off idle but I think my larger tires mask it a bit because I need to give some more throttle to get her moving anyway. I only think about it when I have passengers and try to driver smoother. Would think it's going to be worse with some short rubber. Didn't have any idle problems whatsover, it fit great, I didn't have to pull my M1 off to modify it so I'm happy with it. Looked like a good piece to me and i paid $100 less than a 52mm f&b on the group buy. Put in on at the same time as some 1.7's and it made a gain on top end, no numbers to compare though.
I'm not running the F&B TB but I will say that with a stroker a 52mm TB is too small. I just removed my Hughes 52mm TB and installed a 53.3mm OEM TB I just modified and it made a huge difference. I'm using the 2-bbl M1. I thought about getting the 4-bbl M1 but I'm not sure there is much difference other than the size of the plenum.
I have the single blade TB from John on my truck and have zero problems with it. If wondering, it flows 1000 cfm which is plenty for most builds.
Tanky not to hijack thread but what intake do you run and did you have to modify?
4 Barrel M1 with 2 BBL adapter for the TB to sit on. Fit perfect, nothing needed modifying. I think I might have had to shave the fuel rail mounting pedestals down slightly to allow the injectors to sit properly but otherwise it was an easy bolt on.
Blown and Squirted
To the OP, I would run a large F&B 2bbl unit on a 4bbl manifold with 2bbl adapter. Make sure to port match the adapter to the throttle body.
To Brian- the 2bbl is inadequate for a heads/cam stroker motor, in as cast form it flows something like 235cfm per runner.
1 - 16 of 16 Posts
