Had a bunch of maintenance and repairs done on 2002 Dakota SLT Quad cab with 4.7 engine. New fuel pump solved p0300, 0301 and 0302 codes. Brake fluid replaced and brakes bled trans fluid/filter, transfer case and differential fluid, coolant flush and fill, PCV valve. Brakes feel great, but now abs light and brake warning lights come on occasionally and don't return for a while. Never happened before. Could the mechanic accidentally knocked off or damaged a sensor somewhere? Brake fluid is full. Any ideas?
Sent from my Pixel 3a using Tapatalk
