i'm sure this has been addressed before, but i couldn't find any answers using the search function. i put in a set of 30lb injectors when i did my 408 and i'm thinking they're too much. should i just leave the stock injectors and maybe find a way to install a fuel pressure regulator instead?
my compression ratio is 9.3:1, 555lift cam, M1 4bbl with 2bbl adapter, F&B 58mm, 2.02 heads, SCT with a hughes tune (which i'll probably change soon).
i'm getting pissed here....spent a lot of money on this motor and it's not running right...
