Cam to crank correlation is set with the timing chain and gears. :jester:Not sure, but I don't think it's adjustable...it ain't on my '94 with a 3.9 v6....you can set the cam to crank correlation, but you have to have a scanner to do it.
I may be wrong, someone will chime in here.
SCT flashwhat would be the eastiest way to adjust the timing?
1999 5.9l Dakota
You know what I meant...actually, it's not timing you are checking, it's fuel injector delivery timingCam to crank correlation is set with the timing chain and gears. :jester:
Yep. You're just setting fuel sync with the distributor. Nothing more.You know what I meant...actually, it's not timing you are checking, it's fuel injector delivery timing
I've tried telling them that, but they would rather turn screwdrivers, scrape carb gaskets, and spill fuel to tune.SCT is a lot easier and cheaper than switching to a carb set up.
Unless you buy the PRP software with the SCT, you're still not changing that timing by yourself.SCT is a lot easier and cheaper than switching to a carb set up.
I agree with this post! I want a husky!Little Blue Guy, gorgeous pup in your avatar!
http://www.dakota-durango.com/forum/showpost.php?p=2374610&postcount=11I've tried telling them that, but they would rather turn screwdrivers, scrape carb gaskets, and spill fuel to tune.
Or you can have Hemifever or another tuner change it for you, that would be really hard.Unless you buy the PRP software with the SCT, you're still not changing that timing by yourself.
Okay?? Still going to be cheaper.Unless you buy the PRP software with the SCT, you're still not changing that timing by yourself.
Again, you're still not changing it by yourself.Or you can have Hemifever or another tuner change it for you, that would be really hard.
Who said anything about price?Okay?? Still going to be cheaper.
Why cause you change your setup everyday? If you really want get the PRP for like 375 or something like that.Again, you're still not changing it by yourself.
I use SCT on my stroker. It's a good option. I like it, but I still can't make changes on my own.
The part that I don't like about it is I'm at someone else's mercy. My stuff gets done whenever they can get to it. Hemifever is really good about updating things, but I'd rather be able to go out and make my own adjustments whenever I feel like it.
I don't change my setup every day, but I'm an impatient fuck, and I would like to make changes at the track, not go home, retrieve my e-mail, and go back 3 weeks later when the weather is cooperating on a T&T night. LOL!Why cause you change your setup everyday? If you really want get the PRP for like 375 or something like that.
