Justin Webb said:
I have three check engine light codes for all you smart and advanced dakota owners. My check engin light has been on for a while and i never have time to bring it in. But this is what i got.
P 1281
p 0455
p 0305
Any help would be greatly appreciated. Thanks
P1281 - Engine is Cold Too Long. Sounds like you recently installed a 160 or 180 degree thermostat.
P0455 - EVAP Emission Control System Leak (Large). Tighten your gas cap, replace your gas cap, or make sure the vacuum lines for the evap controls aren't leaking.
P0305 - Cylinder 5 misfire. If you had 2 cylinders misfiring I'd recommend checking to see if your spark plug wires got crossed during a swap, but you may have a single spark plug wire or spark plug which needs replacing.
