lightly sand bumper with 400 grit sandpaper. go to paint store and buy some urethane primer. after you spray bumper and let it dry. dry sand with 360 grit sandpaper. make sure not to go through the primer. then, block wetsand with 400 grit sandpaper. make sure you do not break through primer!
then, its ready to paint.
which direction
is there any direction i should sand or can i go all over in any direction and is that on the whole body kit hood included :clap2: thanks man
im not sure about the hood. If it is already primed just sand it and paint it. Most hoods usually come with a black primer already on them from the company. I'm not sure how cervinis sends out their hoods.
when your doing the sanding; make sure you go in one direction over the entire piece.
