I don't know how you'd get that to work b/c the press is essentially a glorified C-clamp and the part that does the actual pressing needs something flat to press on. If you pressed from the bottom up you'd have to press on the bolt/castle nut itself, which (since it's a ball joint) swivels a little bit 360 degrees, so every time you put pressure on it, it would slip. And believe me when I say, it takes some pressure.Can you press the lbj's back out the top if you don't have an angle grinder to grind off the top and press it out the bottom?
In other words, no, I don't think it's possible. The good news is this is a great excuse to go out and buy an angle grinder :mullet: And, if you consider the fact that tires plus wanted $1,200.00 to do this to my D-go, you'll still come out about a grand ahead even if you buy a really nice angle grinder.
