1 - 11 of 11 Posts
· stupid newbie
I’ve seen a few posts on the forums asking about replacing the column shifter knob. There are some answers, but they follow along the lines of a couple sentences. It was enough to know that there was a pin to remove but I like to see pictures and know what I’m about to get in to. So for those of you, like me, that like to get a little more in-depth info about what they’re about to do, I created this post.
These pictures start off at about ¼ of the way through when I thought “this would make a decent how-to for the other Dakota owners”. So my apologies for the half disassembled steering column in the pics below.
The Problem: My truck is a 1997 Dodge Dakota 5.2 Automatic with a NON-TILT steering column. The shifter knob broke off several months ago.
Items Required:
- A donor steering column. I found a 1998 Dakota steering column WITH TILT on ebay for $60 shipped. A STEERING COLUMN WITH TILT WILL WORK WITH A NON-TILT STEERING COLUMN. Sorry for mass capitals, but the column shifters will match between a 1997 and 1998 Dakota with or without tilt.
Surprisingly, no junk yards around me had a column from a Dakota within the years I needed. I think it was in 1999 that the steering column changed styles; so I stayed with 1997-1998 range. Watch ebay and a cheap unit will show up. Not to mention you’ll also have a backup turn-signal and windshield wiper control module.
- Center Punch (something to push the pin out holding the column shifter)
- T-20 Torx screwdriver
- Philips head screwdriver
- Flat head screwdriver
- About an hour of time
-CLICK PICTURES TO ENLARGE-
1) The offending unit.
Land vehicle Vehicle Car Gauge Auto part
2) The donor column upside down with the covers removed. The donor unit was good practice to see how everything will come apart. Squared in red are where the column shifter came off and the hole for the pin. I suggest you remove and put back in place the column shifter to see how it will be put back in place. There is a spring that you have to push back in order to get the shifter in to place (with the red arrow pointing at it).
Wire Electrical wiring Cable Vehicle Auto part
3) The pin that comes out. I used the Center Punch and tapped it with a hammer from the bottom. The pin shoots out from the top of the column.
Auto part Wire Vehicle Engine Fuel line
4) Remove the front dash face. I put the truck down to 2nd gear, removed the cover, and then put it back in to park.
Vehicle Car Auto part Electronics Speedometer
5) Remove the screws from the main shroud. There are 3. The donor column used all torx screws. My column had 1 torx screw and 2 philips head screws….
Vehicle Automotive exterior Car Auto part Vehicle door
· stupid newbie
6) Top side view when main shroud is pulled apart.
Automotive exterior Bumper Auto part Vehicle Trunk
7) Remove the column shifter shroud. There are 2 screws, one torx and one Philips.
Motor vehicle Vehicle Auto part Car Automotive exterior
8) The slide protector for the shifter will slide out from its guides when the shroud is removed. Don’t worry, it’s easy to get it back in place when re-installing.
Automotive exterior Auto part Bumper Tire Automotive wheel system
9) Slide the rest of the shroud off.
Auto part Vehicle Engine Automotive exterior Wheel
10) Disconnect the O/D wire behind the dash. Tap out the pin holding the shifter in place.
Gauge Vehicle Auto part Steering part Steering wheel
· stupid newbie
11) An underside shot. The grease was heavy so the spring was hiding. Wiggle the shifter back to remove it. The spring isn’t totally loaded so it won’t shoot out of place. I used my flathead screwdriver to push the spring back a little when I removed the shifter.
Auto part Automotive exterior Bumper Pipe Wheel
12) Another shot. You can see the spring.
Motor vehicle Auto part Tire Automotive wheel system Automotive tire
13) The new shifter and the old shifter. The new shifter was pitted so I painted it black before putting it on.
Auto part Automotive window part
14) Make sure to put the plastic shifter cover over the shifter before putting it in to place. It will suck when you go to put the shroud back on and realize you forgot that protector.
Speedometer Auto part Vehicle Gauge Odometer
15) Start putting everything together! Just reverse the tear apart process. Thread the shifter column protector into the grooves of the top and bottom shroud.
Automotive exterior Bumper Vehicle Auto part Car
· Dakota John
A unique problem. Before I got this Dak someone replaced factory shift knbw with wrong after mkt product. Mine is 'forced' onto the column with no O/D button. Should it screw off or are there splines. 1998 4X4 with front and back seats. Column shifter.
How do I remove the four little black needle type pins from the black cluster backing?? I figured out how to remove the little black pegs/needles from the original backing. Woohoo!!! :) just a little bit of patience and perseverance! Here are the before photos of my instrument cluster gauges and new white and red face background!!! :)
1 - 11 of 11 Posts
