great write-up. just changed mine. no melted connections on mine, simple plug and play for me.
VERY good info. I just got mine used from a guy on here, so it was 5 wires, color coded. But that's dang confusing with all those extras you had.It was in fact easy. I do want to add for this group, my harness cam in the form of about 20 wires about 20 inch long half were purple the other half bigger gauge green. Also included in the kit were small thin connectors and the actual black clip that plugs into the resistor.
You only need 5 wires, two of the bigger gauge and three of the smaller
pins 1 pink wire, pin two green wire, pin 3 light bleu, pin 4 bleu/yellow pin 5 brown/balck
My new set of wires came with a connector at one end, I had to remove the cap from teh black female connector and a white rubber band. passing all 5 wirers threww the cap and rubber band and replacing the cap.
With wires now in the connector I spliced the other end to the cut wires underneath the dash with the supplied shrink wrap tubs.
I had allot of spare parts when I was done. shoot I wonder how dodge can get away with selling such a stupid little kit for 100 bucks canadian on an issue that is very well known and documented. You would think that they could build a better fan/resistor combo.
I believe the reason the resistor is located inside the vent system is so that it will be cooled down by the air blowing while the fan is on. It obviously shouldn't overheat, the wires shouldn't be getting hot and melting.This is great information and very helpful. I am a rookie at this, but it was amazingly easy. However, I have a concern. When testing the fan the resistor was extremely hot to the touch. ... is that normal ? I have yet to attach it under the dash. The fan is working properly at all speeds, but I want to make sure I am not missing something. Note: I only replaced the resistor, but wiring harness and connections looked good/clean.
Yes.My fan control just stopped today. It works on high with a/c, but as soon as I change it to a lower speed the fan quits and the compressor kicks off. Is this symptomatic of the resistor block?
Yes they do get hot that's why they put them where they do (in the air flow). Any time you add resistance to the flow of electricity it makes heat Letting them hang out in the open is not good because there is no air flow going over the resistor.However, I have a concern. When testing the fan the resistor was extremely hot to the touch. ... is that normal ? I have yet to attach it under the dash.
This post helped me out a bit. Quite a bit. I bought the kit and damn near sharted myself when I saw all them wires. So kudos to this post. Thank you. I'm going to post pics of the process tonight while I'm doing it that way some peeps know how to solder! and also what to expectIt was in fact easy. I do want to add for this group, my harness cam in the form of about 20 wires about 20 inch long half were purple the other half bigger gauge green. Also included in the kit were small thin connectors and the actual black clip that plugs into the resistor.
That's great info for the thread, thanks for posting. I never thought to compare the resistance readings between old and new. In retrospect I should have put that in the original post.NEW
2-1 0.4ohm ....HIGH
2-3 0.7omh ....MEDIUM-2
2-4 1.3ohm ....MEDIUM-1
2-5 2.4ohm ....LOW
OLD
2-1 0.6ohm ....HIGH
2-3 0.9ohm ....MEDIUM-2
2-4 1.7ohm ....MEDIUM-1
2-5 3.7ohm ....LOW
Still holding up?On another note, for all those shocked at the price of a new harness (I forget exactly what my dealer quoted me, but I remember thinking, 'are you fucking kidding me?') don't rule out the cheapskate method I chose. After my second resistor overheated and destroyed the plug, I cut the factory plug off, stripped the wires, and soldered the fuckers direct to the new resistor. It's not too hard if you have basic soldering skills and it's held up for quite a while now (8 months or so). There's still going to be a lot of heat generated, maybe enough to melt the solder. I'll keep you all posted as to how this repair holds up.
