A printable/PDF version of this How-To can be found HERE.
This how-to outlines the steps for replacing the spark plugs on a 4.7L engine. It is especially geared toward anyone having problems with the tricky #8 plug.
** Note: Click photos to enlarge **
Tools Required:
Procedure:
1. To remove the Air Hat, unscrew these two screws with a Flat Head Screwdriver.
2. Remove the 10mm bolts under the Air Hat and the wire harness.
3. Remove the Air Hat, then unclip the heater line.
Tools Required:
- 3/8” Ratchet
- 10mm Socket
- 5/8” Spark Plug Socket
- Swivel Adapter
- 3” Extension
- 10” Extension
- Flat Head Screwdriver
- Spark Plug Gapper
Procedure:
