Did not work on a '98 model ... DAMN
For the Evap leaks check your gas cap, as well as the rubber hoses that are under the drivers side of the truck. (Pretty much below the drivers seat) They are pretty cheap to replace too.Ive got three codes:
P0158 (M) 2/2 O2 Sensor Shorted To Voltage Oxygen sensor input voltage maintained above normal operating range.
P0442 (M) Evap Leak Monitor Meduim Leak Detected A small leak has been detected in the evaportive sysem.
P0455 (M) Evap Leak Monitor Large Leak Detected A large leak has been detected in the evaporative sysem.
Does anyone know what and how to fix them?
thanks
What are the rubber hoses? o.0as well as the rubber hoses that are under the drivers side of the truck. (Pretty much below the drivers seat).
Vacuum lines - there is a canister mounted to the frame rail.....What are the rubber hoses? o.0
thanksVacuum lines - there is a canister mounted to the frame rail.....
