·P1494 (M) Leak Detection Pump Sw or Mechanical Fault Incorrect input state detected for the leak detection pump (LDP) pressure switch
whats this mean and how do I fix it? :help:
The leak detection pump pressurizes the fuel tank when the truck sits overnight. If it sees a pressure loss faster than it's supposed to leak down, it sets codes for EVAP system. P0455 is one of them...I know this since it's happening on my D right now. I had a friend with a smoke machine force smoke thru the EVAP port and the solenoid on the leak detection pump is the cause of the leak. It's easy to change and should be located right in by your battery. They list for $105 according to AllData.1_Bad_Dakota said:P1494 (M) Leak Detection Pump Sw or Mechanical Fault Incorrect input state detected for the leak detection pump (LDP) pressure switch
http://www.dakota-truck.net/CODES/codes.htmlSinCity R/T said:1999 and earlier Dakotas/Durangos must be read with a scanner, check your local dealership or auto parts store for assistance.
