I bought my 1988 Gen I in the fall of 1999 for $100 dollars. I have since stuck about $25,000 into the whole project and the end result is an 11 second, all motor, pump gas, real world street/strip Gen I. The engine is relatively mild at around 530HP/550ftlbs (est), but is also set up to handle a 250HP hit of N2O... I never got that far because im not sure how I feel about putting a cage in it. I often trailer it to the track with my 2002 because its around 50 miles away...and if it breaks, that would be one hefty tow bill.
451 Stroker Big Block
9.5:1 Compression
ported 906 heads
eddy RPM dual plane
600,750,800 and 950 CFM carbs (Depends on what Im doing on a given day)
727 TorqueFlite
Reverse Manu Cheetah Valve Body
3800 Stall BDR Torque Convertor (soon to be installed)
8.750 A-Body Rear end.
3.55 posi (works out to 3.23s with my 28" tall tires)
Comp Engineering Slide-A-Link traction bars.
Ive gotten as good as 14 MPG (600CFM carb) on the Thru-way\. Durring the summer months, I frequent alot of local "cruise nights" and will typically log on around 3500-4500 miles per summer. It has also run a best of 11.69 @ 116 mph in the quarter mile.
