I want to see what the general consensus is these days regarding changing fluid on a high mileage transmission. More specifically a transmission with 60k plus miles and you do not know the history. Let's assume the fluid is original and the vehicle is displaying no driveability issues yet looks dark and worn.
Theories are that if fluid is not changed regularly and mileage increases the clutch material and band tolerances increase with wear. Friction surfaces may harden or crystalize. The suspended contaminates in the old fluid actually act as a friction modifier and help compensate for the wear.
When the unit is flushed out the new detergents clean the surfaces and all that gunk goes into the filter clogging it up. You may or may not have fluid starvation issues and/or the increased tolerances with fresh fluid makes slipping occur which increases heat and accellerates wear further.
I hear people say shops will not change their fluid on high mileage transmissions and/or make them sign a waiver. I've also heard people claim their tranmssion went out just after a fluid change.
I'm not fully convinced. Until today, I've never had an issue nor know anyone with a failure to occur after a fluid change. On my old 2000 Dakota I changed the fluid the 1st time at 90k miles. I also towed a LOT. I changed it again at 175k miles. It was still solid at 220k miles when it went to the CFC program.
This thought came up as my boss just had the transmission rebuilt on his Jeep Liberty. Uses the same 545rfe tranny. It has about 75k miles and was the original fluid. The local Midas shop talked him into a fluid flush. A week later he tells me he dropped it off at a transmission shop because it was slipping and bucking. They of course told him it needed a transmission. I unfortunately didn't get the oportunity to check it myself.
I'm not convinced it was an actual transmission failure. I'm guessing they either used the wrong fluid or short filled it.
Discuss.
Discuss.
