okay 05 should it be car or truck and what all should i get when i find motorlook for an 05
thanks
Hi there. AWESOME job on an awesome truck. I just purchased this truck that you did the swap on, and I love it. But my mechanic is comepletely stumped by the wiring, and I am completely dead in the water at the moment. Please help! Do you still have the wiring diagrams?:serious: Pm me please, I would so appreciate it. It could save me thousands. I might be out a truck, and the truck is gorgeous and runs amazing! :smile: Help! lolYes I cut out both of those connectors. I used the remains of the 2001 harness to tie into those wires. For example: the wire for the 2001 Dak fuel pump relay to the hemi fuel pump relay wire. Most of it is pretty straight forward. I can help you when you get started. Just PM me and I'll let you know when I can chat. I have all the wiring diagrams and service manuals here at work www.azmobileautorepair.com. I'd be happy to spend a little time and walk you through the rough parts over the phone. Also please forgive the brain fart.... I deal with anacronims all day long and PDU has slipped through the cracks today... Translate?
I don't have any of the wiring diagrams. I had to make a custom, 1 off harness. So use the hemi and dakota diagramsHi there. AWESOME job on an awesome truck. I just purchased this truck that you did the swap on, and I love it. But my mechanic is comepletely stumped by the wiring, and I am completely dead in the water at the moment. Please help! Do you still have the wiring diagrams?:serious: Pm me please, I would so appreciate it. It could save me thousands. I might be out a truck, and the truck is gorgeous and runs amazing! :smile: Help! lol
What kind of problem are you having?
PM me his name and phone number and I'll call him.Could you talk to my mechanic if he called you business hours?
It's not as much the skills, its the means of production, i.e. tools and time, to do the work. I looked at those engine brackets, My Quad Cab is 4x4 so those won't work for me. Honestly if someone could send me the engine block plates, I could cut and weld the factory mounts like Dontshoot67 did. The AC lines I am not sure if I could make or not so that would be another thing.Here is a link to what you need if you are lacking fabrication skills.
http://www.engine-swaps.com/Pages/ProductsYear/9704Dak.html
Did you buy your hemi yet.? If you are buying used perhaps, you can get the donor mounts thrown in. Then use the mounting face from them. Or take some cardboard and make pattern from the mounting area on the hemi block. If I remember somewhere in this thread don said he would make the mounts on request. So maybe send him a message through his profile page.It's not as much the skills, its the means of production, i.e. tools and time, to do the work. I looked at those engine brackets, My Quad Cab is 4x4 so those won't work for me. Honestly if someone could send me the engine block plates, I could cut and weld the factory mounts like Dontshoot67 did. The AC lines I am not sure if I could make or not so that would be another thing.
Are you still looking at this post.if so email me at [email protected]Using sage advice from HemiDak, I used a truck configuration Hemi. Step one was making motormounts. Since the 5.7 bolted right up to the transmission, I left that in the vehicle. I cut the 4.7l mounts apart and made plates that bolted up to the Hemi.
This is quite a while after your post, but un-MDSing a HEMI also requires a non-MDS cam in addition to what you have already stated. Regular lifters are incompatible with the cam lobes intended for MDS lifters.P.S. I have also removed MDS solenoids, wiring, and installed the correct lifters for none MDS.
