I have a 98 doddge durango and its 4 wheel drive but its lowered 3" 3" w/ djm suspension.I have gone through a couple drive axles because they sit in a wierd angle, instead of going straight to my wheels. is there any way i can keep it low or do i have to raise it stock height. only the front is the problem,(i bought the D lowered,previous owner)
you do a couple things put it back to stock if the suspention is like the dakota you might be able to run with out the halfshalfs of corse you wont have 4 wheel drive if you do this put grease on the machined surface on the diff and the bearing to help keep it from rusting kinda redneckish Im sure if there is a problem that im over looking someone will let ya know
Rick
