4.7 '99 wj + radiator failure +overheated+driven(retarded i know but it was 2 miles from home) +overheated + battery died (related/unrealated??) replaced radiator& battery = tries to turns over but won't start
-throws no codes
-changed out spark plugs
-oil changed no chocolate milk.
-there was oil in the airbox/ tb(blown intake gasket?)
just trying to eliminate things,
i hear crank/cam position sensor can have similar symptoms but what are the chances of going bad after an overheat?? anything else i should check before i start pricing heads and long blocks?
-throws no codes
