Hi. I bought a durango from 2008 with 4,7 V8 cheap.
It has only 14700miles and I have to repair it. It's nice car.
The problem is
This vehicle was flood damaged 2012
Somebody changed every module in the car due water damage.
That guy did all wrong and changed all modules to 2007.
2007 model has another engine.
CHRYSLER did a major changes with 2008 engine.
Now I have to change every module.
The first one I have is PCM
Now I have to change BCM to.
My question is. What modules do I have to change besides these two I mentioned.
Do I have e to reprogram all modules or configure these
Is VIN on BCM important to match?
Is VIN important to match with all modules?
The only module that is original for the engine and 2008 model in the list below is ABS.
I got right PCM for 2008 model.
05150281AB
VIN number for my vehicle is
1d8hb48n38f123726
VIN number for the wrong donator car is
1d8hb48p27f583671
Here is some text obout all modules.
pcm
model year 2007
ecu part nr 05094771aj
vin original 1d8hb48p27f583671
vin current 1d8hb48p27f583671
software version (major middle minor) 09 07 01
hardware version (major/minor) 0c3f
serial number TI0EH1387JECYJ
body style rs
vehicle line hb
suplier id 08
diagnostic version 65
variant id ngc 4 in production
vmm version 3105
usa
p0508 idle air control valve sense circuit low
p0330 knock sensor 2 circuit
p0135 oxygen sensor 1/1 heater performance
p0141 oxygen sensor 1/2 hester performance
p0155 oxygen sensor 2/1 heater performance
p0161 oxygen sensor 2/2 heater performance
ABS
vin number 1d8hb48n38f123726
ecu part 68003123AE
software version e419
diagnostic id 00
variant id 08 abs rwal esp asr
supplier id bosch
model year 2007
vehicle line hb¨
body style 4 door sedan
usa
software code partnumber 6191304.00
c107c brake pedal switch 1/2 stuck
c2202 original vin mismatch/missing
c1000 brake pedal switch 1 ciruit performance
orc/srs
ecu part number 04896158ad
software version (major middle minor) 373141
hardware version (major/minor) 4149
diagnostic version 54
variant id 01 orc can b
ecu origin dca
model year 07
vehicle line hb¨
usa
serial number tdume1617u4404
BCM body computer
ecu part number 04692103ag
software version (major middle minor) 070007
hardware version (major/minor) 4142
diagnostic version 59
diagnostic variant cgw (fcm)
supplier id huntsville
gateway ecu true
software code part number 04692103ag
serialnumber t24eh151770rd2
b230e rear wiper park switch input circuit high (stuck high)
c1405 active transfer case range position sensor circuit high
b2336 horn control circuit low
b1640 front right turn lamp control circuit high
p0073 ambient air temperatur sensor circuit high
radio
ecu part number 05091175ad
ccn/instr
cabin compartment noe/instrument cluster
software p/n 10093326ad
ecu part number 05172098ah
serial number tq3qi091708816
WCM
ecu part 05026173af
DDM drivers door
ecu part 04602922ab
ecu original dca
serial s91ff145712793
pdm passanger dorr
ecu part 04602922ab
ecu original dca
serial s91ff145710878
amp
ecu part 05064141ac
eom electric overhead module
ecu part number 56046107aa
year 07
SAS steering angle sensor
no supported module information
sdar satelite digital radio
ecu part 05064075ae
serial
TxxDR145773992
The problem is
05150281AB
1d8hb48n38f123726
1d8hb48p27f583671
pcm
model year 2007
body style rs
vehicle line hb
suplier id 08
vmm version 3105
usa
ABS
ecu part 68003123AE
diagnostic id 00
supplier id bosch
model year 2007
vehicle line hb¨
usa
orc/srs
ecu origin dca
model year 07
vehicle line hb¨
usa
BCM body computer
gateway ecu true
radio
ccn/instr
WCM
ecu part 05026173af
DDM drivers door
ecu part 04602922ab
ecu original dca
pdm passanger dorr
ecu part 04602922ab
ecu original dca
amp
ecu part 05064141ac
year 07
ecu part 05064075ae
serial
TxxDR145773992
