·Hi
I recently purchased an '01 Durango w/4.7. I've noticed that the heat(haven't tried the air yet but would assume its doing the same) doesn't seem to be working exactly right. The dual climate control doesn't work right either. If you adjust one it changes on both sides. Also it seems that when you turn the heat off there is still air coming out the def vent and when you switch to feet it blows out the def vent. Has anyone had this problem or know of anything I can do?
Thanks
Mike
[email protected].k12.va.us
Thanks
Mike
