1 - 5 of 5 Posts
I own a 01 r/t. Recently the driver side low beam will not light but high beam does. No problems with the passenger side. I replaced the bulbs and that did not work. I don't want to take it to the dealership but if I have to I will. Anyone please help. I'd appreciate it. Fuses are ok as well.
It could be the CTM. There is no relay for the high/lows.
The CTM powers the headlights. On connector 3 of the CTM:
Pin 4 (violet with white tracer) is the feed for the low beam.
Pin 3 (light green with brown tracer) is the feed for the high beam.
Check the ground too.
idk about 01's but my 98 was doing the same thing and it has four headlight fuses either under the dash on the backside of the fuseblock or under the hood depending on model and year.
1 - 5 of 5 Posts
