T-10 torx head screw in the corner between the headlight and the corner lense. Unscrew that, pull the corner lense out, turn the base of the bulbs until they come out of the lense and take the corner lense off. Then there should be 3 bolts holding the headlight on and for some reason I want to say they're 10 mm. Anyway, get those bolts out and pull the headlight off. From there, unplug the bulb from the wiring harness and out comes your headlight.
