1 - 7 of 7 Posts
Just wanting to find out when you would be getting these tire back in stock in 275/55 17. I can order a set from tire rack thay have them in stock but I would rather get them from you since my last 3 sets of tires I have ordered from discount and never had a problem thanks.
Thank you for the post.
The 275/55-17 RH07 was recently released off back order and is available through Hankook. We can order a set in for you which makes the lead time to your door only 7 to 10 business days. Give us a call at 1.888.459.4080 and anyone of our sales agents would be happy to set you up.
Thank you for your continued support!
408,R3,Indy Heads,Twin66s
How do these compare to the RH06's? It appears that they don't make the RH06 in that size anymore.
The RH07 is not as performance geared when compared to the RH06 but is a good option for replacement OEM all season tires. Like you noted, the RH06 is not produced in the 275/55-17 size.
I am looking for a high performance tire in that size. I could live with a little wider and about 1/2" taller or shorter. I would like to keep the same diameter if possible. Can you recomend anything?
The General Grabber UHP is produced in the 275/55-17 size and would be a good option to consider. We do not stock this model but we can order a set in for you. Our current mail order price is only $157.00 per tire with FREE delivery.
1 - 7 of 7 Posts
