i need to tap into an igniton wire for my air fuel ratio, radar detector, electric fan, etc. i know i can put em on a switch, but i want em to start up when i start up my truck. anything under the hood i can tap into that starts up with the enigne that wont ruin anything?
check in the fuse pannel in the cab. when you open the door you should see it on the dash. Use a tester to check which gets power when the ignition is turned on
There is at least 3 taps in the fuse panel on the side of the dash that are ignition controlled - make sure you use a blade fuse when tapping into the system and use relays in conjunction with any high-amperage items such as the electric fan.
