1 - 14 of 14 Posts
· #19 ƃop ǝnןq ǝןʇ&#
My 94 never had one from the facrory, probably because it was a 2wd Sport....I know the 4wd trucks had them on the passenger side...my question is this:
Were the "Oh Shit" grab handles ever put on the driver side?
(I put one on the passenger side a while back, so I have one there)
Bryan
I just installed a new headliner in my 95 Sport - it did not come from the factory with grab handles but had the holes already drilled for one on the passenger side, so I added one. I found several at the local Pick N Pull - they all had passenger side handles only. I suppose one could be added to the drivers side.
If you get one, be sure to use the screws from the donor - they are very short. Anything longer will bottom out on the roof sheetmetal.
· Tire Hater
Every vehicle I ever owned had an Oh Shit handle on the Drivers side.
But I always called it a "steering wheel"
:jester: yuk yuk.
Reactions: Little Blue Guy
Discussion Starter · #4 ·
yea..my headliner is coming un-glued..it's one of my many projects to do this year..I have another grab handle..plus another coat hook as well...I plan on installing both when headliner is out
Bryan
I don't have a headliner in my truck, interior is stripped out. The pass side prominently has mounting locations for a handle plus recessed location for your hand, the drivers side does NOT have any provisions for mounting a handle there. Not to say you cant do it but there isnt really a proper way to mount it, the bracing for the pillar has large holes in it for weight savings so it doesn't entirely leave alot of meat left to mount a handle.
Why would you need one on the drivers side though? You do have the steering wheel where the passenger has nothing... Personally if your in a situation where you might need a handle like that you probably should have both hands on your steering wheel, but you generally should at all times anyways.
· ¯\_(ツ)_/¯
Hey Bryan :wave:
I pulled my headliner out to redo it and started thinking about this thread. So I decided I wanted a handle on the drivers side too. So i just need to go pick some up from the junk yard. I grabbed a couple pictures of each side.
Passenger side (With handle taken down) Has some extra bracing and pre-drilled holes.
Driver side no extra bracing but enough metal that I could pre-drill some holes and screw up this handle to it and it is still very sturdy.
This got me thinking. I have an extended cab so why not throw some back there as well. So i pre-drilled and put put them up centered over the coat hooks.
Now I also noticed in the back two pre-drilled slots above my rear window. In the regular cabs is this where they had the coat hooks? either way I will be putting a couple hooks there as soon as i finish the headliner.
Hope this helps someone some :D
-Carl
Discussion Starter · #9 ·
Mine only has the one coat hook in my reg cab.....for now...I got another hook here....but I gotta take my headliner out and re-glue it..it's falling down....then I'll put in the second hook and maybe the drivers side "shit" handle
Bryan
Discussion Starter · #13 ·
I still have not installed my drivers side handle yet...ain't fixed the headliner either..I should have done all this when I put the stock overhead console in, but I didn't
Bryan
Bryan
Bryan
My 02 Dakota quadcab has a driver side oh shit handle.
1 - 14 of 14 Posts
