1 - 1 of 1 Posts
SoutheastR/T
Gen 3 5.7 / 6.1 Hemi Distributer Conversion Kit.
This kit is a completely customized kit that allows you to run your Gen 3 5.7L / 6.1L HEMI without the need of expensive break prone electronics requiring flash upgrades.
The conversion was designed for those 2008 and older, Non VVT, MDS version car engines. Those have different covers, cams, manifolds compared to 2009 - up engines with VVT and MDS.
The Gen 3 Hemi ignition conversion will not fit on a Hemi truck engine. They use a different timing cover and manifold compared to the car version.
You can use stock cam or any upgrade cam using the included conversion components.
Includes a custom made Hemi Race Billet Distributor, black 8.5mm universal length wires, aluminum cast front cover, front timing gear, fuel pump push rod, all hardware Does not include fuel pump.
We carry both aluminum intake manifolds for EFI use or carburetor manifold conversions including new Holley carb or Holley Sniper.
Also, MSD is available for those engine swap applications where no factory pcm is utilized.
Contact us for pricing and availability.
1 - 1 of 1 Posts
