Just like any engine swap there is going to be some fabrication and a lot of time to make it happen. I’m not sure what the differences in the harnesses are but getting a 5.2 harness would probably be the easiest way, also don’t forget that you will need a 5.2 ecu aswell. You will have to figure out motor mounts, maybe transmission mounts, driveshaft, etc. How hard the swap will be really depends on what options the 2 trucks had (4wd, ac, manual). If you search on google or YouTube I am sure you can find someone else who has already done the swap and that is probably your best option to find info.
