Using them on mine.I'm going to look for cork for this particular gasket, any one using cork LA gaskets?
ThanksUsing them on mine.
The Magnums are rubber over steel w/10 bolt holes, the LAs are cork w/5 bolt holes and they will not interchange.What are the differences in the magnum and LA valve covers? Is it just bolt holes?
Good info to know if I ever need another set for my RT. :mullet:MOPAR Performance makes the Rubber on Steel for the 'LA'. I know for a fact I have 2 sets on my 'LA' Due to the Edelbrock intake flange being so thick.
MP Part number P5249581AB but at summit drop the 'P'
Summit Racing http://www.summitracing.com/parts/DCC-5249581AB/
Can't beat them.
If you have adjustable rockers and have to take the valve covers off one time they have now become cheaper than 'Cork in a Condom' gaskets as well as much cleaner, no 'snot in a tube' needed. And they never have to be replaced, no matter how many times you remove the valve covers and they don't slip off when you are trying to put on the valve covers and they 'never ever leak'. What was that thing my Grandpa used to say, " You get what you pay for Boy".wow, I won't be dropping $60 for some valve cover gaskets. I've seen rubber on cork and plain rubber online, I haven't checked locally yet.
