on my 2009 Dakota 4.7
my gas cap indicator comes on under my odometer
I replaced the cap cleared it on my code reader(hasn't showed up all the time),but keeps displaying on my dash.
Any think else I can look at?????
Thanks
Mike
Unhook your battery for a while (Turn the ignition to 'On'), and that may reset it.
Are you using an OEM gas cap?
It could also be a slice in the filler hose, or a leak in the breather hose.
thanks
disconnected the battery as you said checked hoses all good
was ok for a day or so then reappeared again....
Discussion Starter #4
also having heating issues,blower works at different speeds as it should but no heat temperature gauge goes to half but blowing cold air..
any thing I should look into would be great its almost fall here in Newfoundland and we need heat lol...
