Fuel volume
301 Views 1 Reply 2 Participants Last post by  Dodgeowner
Hey. I’m new to the site so hopefully I’m posting in the right spot.
I have 05 Dakota 4.7l quad cab and I’m having an issue with the truck bucking and stalling upon acceleration under load. No check engine light and no pending codes. I have have a new pcm( installed and programmed by dealer) new map and crank and cam sensors. TPS voltage test is normal and spark plugs and coil packs are new. I did a fuel pressure test this weekend and it sits between 55 and 60 psi. But quickly starts dropping if I don’t turn the engine over. I wanted to do a fuel volume test and was wondering if anyone knows how much fuel I should get after 30 secs (or a minute whichever). Thanks
If you haven't fixed it yet, could be an injector leaking or the fuel pressure regulator and the anti drainback valve
