61 - 80 of 91 Posts
I work at a machine shop that does ship maintence during the winter so I usually don't have time for the dakota stuff unfortunatly. In the spring when that slows down I'll be able to catch up on the fun stuff.
If you could read you'd realize he dosen't do this for a living, it's more of he WANTS to help the community when he can. As stated there are other options so why are you guys loosing sleep over this? If you wanted a set a rails asap take your business elsewhere....Are you in heat?, because your sounding like a bitch. Grow up
For those who are not in a rush like myself I have no problem waiting. I'm supprised at the maturity level here, somtimes I have to check that I'm not on cobaltss.net or jbody.org.....
Deanler- Let me know when you get around to making rails as I'd still be interested.
Discussion Starter · #65 ·
Sounds like someone gets it. We've had a a busy year at work and the time i would usually spend making Dakota parts was spent at work on overtime, which pays a lot more than making fuel rails unfortunatly for black night
· Premium Member
Mythical rails? Hey easy buddy just because they are mythical doesn't mean u shouldn't believe in unicorns. All I did was say hey I might make some too but u have the first buyers didn't post since feburary. I didn't mean no ill harm man.
Justin please send your fuel rails back to me to discard of so you can purchase brandon burns mythical rails that he hasn't made yet
Did I ever show you my finished set up? I scrapped your mounts cause I got the M1. And it took some time to work out the inlet and feed to both rails, turns out there isn't a whole lot of room back there for fittings
Discussion Starter · #75 ·
I havnt seen that, It looks good! Your Y isnt a bad idea either, I have my harness tucked under the m1 so theres lots of room for the port under the drivers rail, with the wiring in the stock location like you have I can see how it might get a little congested.
I tried to run it inside the intake valley... got most of it done and then switched it back. I don't remember what the last straw was on that one :jester:
61 - 80 of 91 Posts
