Wut size cups or plates should i use on my front i have factory control arms?
I have 2 Slam Specialties HE-7, 7" Diameter 400 PSI Rating Single 1/2" Port (2) 3/8"-16 Mounting Holes Top (3) 3/8"-16 , for the front, i have pre- ordered Do-It-Yourself Coil spring bag brackets
This kit includes 2 upper bag mount plates, 2 lower bag mount plates and 2 feet of 4 inch diameter tube. This kit you can cut the tube to the right...
should i use 4.5" kit o5 5.5" plates?
Do i weld a plate on the lower control arm, to bolt the bottom of the bag to?
I got everything for the rear including shocks. will all this fit in the front end non 4x4
did i mention i have 24x10" rims
