1 - 5 of 5 Posts
I see alot of guys with the 5.2 and 5.9 are relocating the IAT sensor. Is this mod possible with the 4.7?
Its possible but it depends on where your IAT is located at. Some of the trucks have them located allready in the air inlet tube. Mine is located in my throttle body. You would just have to look at it and make sure.
If mine is located in the TB, should it be moved or is it reading a coller temp where its at?
Honestly I couldn't tell you. When I found out mine was in the throttle body I said screw not gonna mess with it. I just went ahead and put a cold air intake on the truck.
ya if you move the iat sensor out into the colder air then its not reading the correct air temp, as the air comes in it heats up and if your not reading the correct air temp it messes with the air to fuel ratio. its better to devise a way to get the coldest air to the sensor not the other way around.
1 - 5 of 5 Posts
