· Home School Valedictorian
Any one know of a plate made to repair rusted frame where the front and rear frame bolts together above rear axle housing ? Thanks
I don't know anyone that makes them but, what I did was made templates of the area I wanted and had a local metal fab shop plasma cut them for me.
91 Dakota
Hi, I can cut a flat plate I want to cover top and lower flange.To do that I need to make three parts and weld together.Be a little fitting! My 91 the gas tank set against the one piece frame at the same place,needed to remove bed& gas tank cut out 12 in of lower flange where the salt and road cinders laid,bend a new piece and weld in.This wouldnt be as easy.Pa tough on inspection on frame rust.Thanks for reply!
