Problem solved. I completly dissasembled it and reasembled it. The led is also in there and working now. Not quite sure what happened as it was rebuilt the same way both times. I do notice now that if I lean the switch to the right when the fogs are on it may trigger them to go off unless you move it back. It may have always done that, not sure as I don't use them often. I was just playing around with them and found that out.
